door/window trim
  • jrobie79
    • Mar 2006
    • 2525
    door/window trim
    so I removed my shadowline trim to repaint everything (car is getting repainted too)...and there was this putty stuff under the b-pillar trim...I'm assuming it helps with any "flapping" of the as there are only clips around the edges...
    what are you guys using when you put your trim back on, if anything?
    1991 318i ---- 308K - retired
