Door gong
    Door gong
    Hi all,
    I am almost done with my build but 1 thing that bugs me from the shell that I am using is the door gong is not working. I have tried two different speakers, and no dinging or anything when door is open.
    I'd like to have it but i know some people disconnect these. Are there any common wires that I should check to get this working again? Or possibly my two speakers i am trying are bad?
    '99 e46 323i - wrecked
    '87 e30 325iS - sold
    '91 e30 325i - sold
    '89 e30 M3 - fun car
    '09 e91 328i - sold
    '97 impreza - rally car - flipped
    '08 impreza - new rally car
    '01 996 tt - more fun car
    '82 Ford f350 - work truck
    did you make sure that your gong has 2 connectors connected to it not just one?
      Originally posted by 88BlackS-ETA
      On the drivers side there is a plunger/plug that lets the dome lights turn on when the door is open. It has a Phillips screw that holds it on the front of the door frame, take it off and pull the plunger/plug out and check to see if both wires are connected.
      I will have to check this out
      I only see 1 connection going to the gong, the one with the slanted edges. It seems that I am completely missing the other wire as shown in this pic:
      Not sure where this other wire would be hiding, where does the other wire connect to?
      '91 e30 325i - sold
      '09 e91 328i - sold
