how often should i replace the waterpump?
  • ptownTSI
    • Jun 2005
    • 1265
    should it be done every time the timing belt is changed?
  • backtrail69
    • Jul 2005
    • 4471
    I would do it every time you change the timing belt along with the v belts and dist cap and rotor, It is just easier doing it like that. I would prolly do my thermostat too. I Did all that when i replaced the HG in my turbo car as well as all the top end gaskets.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • PУCCKAЯ_e30ka
      • Jan 2006
      • 1226
      i think that /\/\/\/\ would be a waste of water pump money, unless you have a turbo or a stroker, just replace it once for every two t-belt changes
      • AdironRider
        • Dec 2004
        • 3491
        Id do it every t belt change as you might as well while your in there and whatever, its like 60 bucks or something. Better than having it fail and you have to pretty much the whole t belt job again for nothing.
        Back to my roots
        • Axxe
          • Aug 2004
          • 3355
          Exactly.
          You can only tension a timing belt once, so if you have to go back in to do the water pumpl, you loose more money than you saved by cheaping out on a $60 maintenance item.
          Keep it slideways!!
          • PeaveyBassist
            • Sep 2004
            • 3511
            Every timing belt change as recommended by BMW.
            Will
            RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
            Welcome e30 (brilliantrot '90 325is) 12/23/06
            DaveCN = Old Man
            My signature picture was taken by ME! Not by anyone else!
            If people keep quoting me in their sig, I'm going to burn this motherfucker down.
