This is on a GTS-1 race car, M20.
Fuel filter became clogged on a regular basis, figured I would drain tank, check FP sock. THought I had 10 - 11 gallons, got 3 gallons out. Pulled sender, passenger side was empty, drivers side was almost full. Fuel is not crossing back into passenger side.
I have another clean late tank in the shop, tested with compressed air to see how crossover tube worked, could not get air or brake kleen to go through. On the tank in the car, pulled it out and fuel/air seemed to move through the tube fine...
So does it work backwards? Some sort of vacuum created?? Thinking about testing a 3rd tank...Replacing all the vent lines as the tank is out...anything else to look for?
Thanks
Al Taylor
Scuderia Gonzo Alonzo
wabmw25@aol.com
Thanks
Al Taylor
wabmw25@aol.com
