Hoping someone can help me figure this out. My 325e has been overheating recently. Seems that It gets bled and the temp stays fine at either 1/4 or just under half temp. After about 250 miles of driving with no issue, the temp starts to creep up. Today it crept up to almost red so I pulled over and just like the first time I saw the coolant was bubbling through the reservoir cap. I let the car cool down and then opened the cap, let it finish bubbling, and then opened the bleed screw a little and let the hissing noise which I assume was air, get out. Then I was able to drive it home and instead of going up to red it just stayed steady at 3/4. I'm going to run through the diagnostic threads I found here but wanted to ask if this sounds like anything that anyone is familiar with. I noticed that when driving up hill the temp will rise a little and when going downhill it will lower. I was thinking it's the radiator? What else would cause air to keep entering the system?
Also I had my o2 sensor replaced to solve a problem I was having with the car revving up and down whenever in neutral. Tonight while driving it started to do the revving again - I'm assuming the higher temp may have burned out the o2 sensor or maybe some of the coolant that was pouring out ended up messing it up?
Any ideas? It drives great for the 200-250 miles between overheating episodes. Not sure what could be happening in that time to cause it. Not driving the car hard either.
Thanks
Thanks
