A touchy subject r-152a refrigerant
  • Kevinl
    • Oct 2012
    • 897
    After spending almost $900 to convert my e30 to 134a the right way parallel flow condenser new 134a expansion valve new compressor, drier
    and the a/c was still pitiful I live in the closest thing to hell 6 months of the year and having no bueno a/c in the e30 was wearing on me
    I had heard of others having sucsess using 152a aka "air duster" in r-12 vehicles, so desperate I decided to give it a try I bought 3 cans and charged 1.5
    in and it seemed overcharged so I took some back out and probably ended with
    1 can worth and the change in performance was amazing I hit 38.4 degrees on the highway and its stays around 43 degrees or lower on surface streets sitting at idle is still leaving something to be desired but with this puny condenser I cant expect much
    I am not saying yank out your 134a and put this in but if you live in a hot box and are not satisfied I would certainly give this a try
    1989 BMW 325is Lachsilber metallic 5 speed
    2007 BMW 335i KARMESINROT 6 Speed manual
    2011 BMW X5 35I
  • Ether-D
    • Sep 2011
    • 2838
    Iiiiiiiinteresting...
    Originally posted by Andy.B
    I was born on 3/25…
    • jrobie79
      • Mar 2006
      • 2523
      how did you introduce it to the system? do the cans have the same thread on hose thingys?
      1991 318i ---- 308K - retired
      • Poorboyz
        • May 2012
        • 2117
        Interested in how you put the content of the air duster into the E30 system.
        Sent from my 831C using Tapatalk
        Rebuilding since 07/06/2016
        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
        Poorboyz Feedback Thread
        • Kevinl
          • Oct 2012
          • 897
          I recovered the r134a pulled a vacuum on the system then used a can tap that i bought from napa you need one that works for r12 as the r134a cans are larger but the duster cans are the same size as r12 cans
          2011 BMW X5 35I
          • Kevinl
            • Oct 2012
            • 897
            Here is the tap i used
            2011 BMW X5 35I
            • ELVA164
              • 4861
              Just did about 5 minutes of research and learned two interesting things:
              1. It's flammable
              2. Ignition creates hydrofluoric acid, which can also happen with R-12 and R-134, but not as easily due to those not being flammable.
              • SmokeE30
                • 1730
                Why not use r12, it works the best and the e30 system is designed for it. Unless you need to be able to grab more refrigerant from wallmart 24hr a day just get the right stuff and enjoy cold factory AC
                Shawn @ Bimmerbuddies
                Bimmerbuddies LLC
                717-388-1256
                2971a Roundtop Rd, Middletown PA 17057
                bimmerbuddiesllc@gmail.com
                • Kevinl
                  • Oct 2012
                  • 897
                  Nothing wrong with r-12 if this didn't work thats what I was going to do but it is expensive if I was gonna go back to r-12 I would buy a 30lb tank and have enough for life
                  2011 BMW X5 35I
                  • TurboJake
                    • 3780
                    Fun fact.
                    I had a funcational R12 system. Worked great, then died (Just slowly leaked enough)
                    Filled with propane just to prove a point to someone who didn't believe me. Worked great for 10 minutes, then drained it. Then, while he was still watching me, I switched it over to R134a with just the conversion nipple, using the stock equipment Worked great for a year. Blew the condenser in Colorado on my road trip. Replaced in cali with another factory unit (for $15!!!). Still works great.
                    Moral of the story. My car is fucked up 9 ways to sunday and everything on it still works. Which is fucked up.
                    Leave Me Transaction Feedback
                    • lambo
                      Captain Scene Points
                      • 10953
                      Originally posted by TurboJake
                      Fun fact.
                      I always wonder if I'll have AC in an E30.
                      • AwakenNoMore
                        • Dec 2010
                        • 1291
                        I threw a can of Envirosafe in my car recently, it got the system working but i am less than thrilled with the performance, but in az i'll take anything i can get.
                        1991 325i - "Scambles" The Daily Driven lightly modded.
                        1988 Mazda RX-7 TII "Mako" The Free Dorito
                        bacon by Jared Laabs, on Flickr
                        • Kevinl
                          • Oct 2012
                          • 897
                          Give it a try i have been thrilled so far with mine
                          I used to dread driving the e30 between april thru september
                          If you want to give it a shot i have everything you need just buy some air duster with diflurothane and come by
                          2011 BMW X5 35I
                          • AwakenNoMore
                            • Dec 2010
                            • 1291
                            might take you up on that offer, however before i decide to i think i might replace a major amount of the system with new bits, my system is leaking slowly i'm sure.
