as long as i get the large size guibo and large vibration dampener and use the 8/87-92 center bearing?
can i use an old style driveshaft on a post 8/87 car?
The mounting location for the center support bearing is a different size/width between late and early model E30's, as is the housing of the bearing itself. You just need to use the right CSB for your car. They aren't driveshaft-specific, just car-specific. The bearing is the same size.
But yes, you will need the larger flex disc. And forget about the vibration dampener, it does jack. -
So late model driveshafts use small flexdisc and early model use large?
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
wellll crap i guess i wont be using the driveshaft i bought then, i dont feel like changing the output flange on the trans. unless its easy, i need that thin wall 30mm wrench or is it 32mm? i'll just run the driveshaft i have with the spicer u joints (rebuilt) that i was going to have rebuilt again and put in a nicer e30 when i got it, but this is getting to be a pita.Comment
