Alright guys, first m20 just came to me Saturday. Test drive her for 45 min, ran great besides the sloppy shifter bushings, and broken exhaust between the cat and muffler. So I bought it, 15 minutes in to the hour drive home going 70-75mph 3200rpms, she cuts out and wouldn't accelerate or rev.
So I got her towed home, she's getting gas, no spark... So I changed the battery, main relay, the cap and rotor, coil, spark plugs and wires, CPs(CPs was spinning and wiggling but not coming out easy, Took a couple hours of sitting there, butch was jammed hard) Still no spark... I changed the ground from the rear of the valve cover to the engine bay battery tray, as the old one wasn't looking good. And the ground in the trunk to the battery... Still nothing... Any ideas?
Also we found a 3rd wire maybe a ground? Going to the coil but the end was nt connected to anything... It wrapped around the passenger fender around the back of the motor, and then went under the fuse box but wasn't connected to anything my buddy said it went thru the fire wall but I looked under and there's no wire ripped/cut the same way
Help? Please and thank you
