HELP NEEDED: Key broke off in door
  • audiRS4ever
    • Jul 2014
    • 25
    Hello all,
    I went down for a weekend to visit some family at the shore, and locked the car when I parked. I went to unlock the car and the key broke in half. I do not have an extra key with me, and the car is still locked. Any advice? Can these be easily broken into/hotwired?
  • Best_name_available
    • Jul 2014
    • 479
    considering your name is audirs4ever I'm not sure I should help you...
    Originally posted by Vokuhila
    I laughed, and then I serioused
    • sublimation
      • Jul 2013
      • 155
      I told you what to do
      • jalopi
        • 2370
        From what I understand, the steering wheel lock is a real motherfucker to defeat. Unless you've got an aftermarket wheel, you're screwed there.
        Two options:
        1. Take your title to the local BMW dealer and they'll make you a key. You'll also need to replace the drivers' side lock cylinder unless you figure out a way of getting the key out. Total cost? About $70 and a few days.
        2. Call a locksmith. They will come to your car, extract the key and make a dupe from the two pieces, right then right there. This does come at a cost though... expect to spend about $150-200 for this service.
        • jrobie79
          • Mar 2006
          • 2518
          if you have AAA they reimburse up to $100 for new keys made depending on your membership level
          1991 318i ---- 308K - retired
          • AndrewBird
            The Mad Scientist
            • 11892
            Definitely call a locksmith. They will get the broken off key out and cut you a new one.
