e30 Car horn not working
  • park123xyz
    • Aug 2014
    • 147
    Hey guys... Where should I begin if My car horn is not working on my 88' 325iX? I have checked the fuse and it seems fine.. The only reason I meed to fix it is to pass inspection. Should I just install a temporary one for it to work and so i cam pass or what? Also where is the horn located on my model I cant find it! Lol.
  • dnguyen1963
    • Nov 2011
    • 2651
    Have someone press the horn button on the steering wheel while you listen for the relay clicking. If it does click then your horns are dead. They are simple to replace. You can buy replacement horns from many places for about $10/ea. Horns are located up front. Remove the splash guard, craw under, and you can see them...one on each side.
    • park123xyz
      • Aug 2014
      • 147
      Thanks!
      • park123xyz
        • Aug 2014
        • 147
        Does anyone know if this relay is good for the horn relay??
        http://www.pelicanparts.com/cgi-bin/...orter=date_new
        • ST1G
          • Oct 2012
          • 6689
          Yes, Bosch standardized relays. That one will work fine.
          • long tall eta
            • Jul 2010
            • 1536
            is there a connection in the steering wheel that can also fail?
            • ST1G
              • Oct 2012
              • 6689
              Yes, depending on the wheel.
              • long tall eta
                • Jul 2010
                • 1536
                mine's not working, relay is good and i doubt if both horns quit at the same time. sport wheel.
                • ST1G
                  • Oct 2012
                  • 6689
                  The sport wheel has connectors inside the button. Pull the button off and make sure they are connected and not corroded or loose.
                  How do you test to make sure the relay was good?
                  • long tall eta
                    • Jul 2010
                    • 1536
                    swapped relay with known working one. don't now if it maters but the wheel is an mt1
                    • ST1G
                      • Oct 2012
                      • 6689
                      Perfect. Make sure everything inside the horn button is connected up.
