How do the wires connect to water temp sender on M42
  • nickmpower
    • 82
    does anyone know in what order the wires connect to the sender? i think ther is a green and black and a brown and black and a black
  • nickmpower
    • 82
    could someone with a m42 318 just go out and look?
    • kencopperwheat
      King of Kegstands
      • 14396
      Isn't it in the Bentley manual? Or does he E36 version cover the M42?
      Originally posted by Gruelius
      • nickmpower
        • 82
        yeah its not in my e30 one
        • kencopperwheat
          King of Kegstands
          • 14396
          post the question in an e36 forum. im sure you'll get more responses
          • 318daily
            • 507
            i'll be happy to look. where's this water temp sender thing located ?
            Our mission is to provide solutions for the technology needs of our clients, while maintaining the level of efficient, friendly and trustworthy service that is the foundation of our methodology. Call Method Technologies at 844-463-8463.
            you can enlarge that pic to get a higher resolution. I'm guessing it's that thing at the top passenger side of the radiator.
            • nickmpower
              • 82
              yeah but urs has some cover thing mine doesnt have, could you take it off and see? you might be able to see anyways. it looks like it goes brown/black, green/black, black from top to bottom but im not quite sure
              and if you still have ur engine apart like that be sure to adjust ur timing, i wish i would have done it to mine when it was apart http://www.r3vlimited.com/Tech/318is.htm
              thanks
              • 318daily
                • 507
                Yes you are correct. That is indeed the sequence of the wires.
                • nickmpower
                  • 82
                  I took the sensor off and inside it had a 0 by the wire in the middle which i think would mean ground and a t1 and t2 by the top and bottom wires. Are you sure thats how the wires go? I would think the black would go to the middle ground wire. Could you try touching each of the 3 wires to a place thats grounded? when i do this the gauge doesnt move and i think its suppose to.
                  thanks
                  • nickmpower
                    • 82
                    • 318daily
                      • 507
                      Tthe plug it has this sequence of numbers:
                      3 1 2
                      3 - brown/black
                      1 - green/black
                      2 - black
                      I didn't pop off the cap, but pryed it far enough to see that each wire was indeed going to their respective pins.
                      hth
