Does anyone know if the late model 318is and 325is have the same wiring for the A/C compressor/radiator fan temp switch? A member here has it from a 318...
Basically the PO on my car did a retrofit for the A/C and the wiring is all messed up and spliced plus the wiring plugs are all broken. I need the wiring from the Radiator Fan switch Sensor to the A/C compressor....all located at the front of the passenger side engine bay around the washer tank. Not even sure what else would be in that same harness - like washer tank level sensor, etc
Thanks!
Thanks!
