Kind of a long shot, but I recall seeing a leaking oil pressure sender push the oil up the sleeve surrounding the sensor wire, and the leak then appears to be near the alternator.
Weird Oil/Coolant Leak, Help!
Happened to me not too long after i dropped in my new used engine. not a long shot at all really, it dripped haneous amounts of oil for me though. had to fix asap. got the sensor by duralast from autozone, less than $10 IIRC
--Mike(OO=[][]=OO) For LifeComment
Hmmm this is interesting. Where exactly does this sender thread into the block?
I'd say the amount I'm leaking is quite a bit as well... But it's only when it's running which is what made me think it was definitely related to the oil pressure.
I'll definitely check this out when I get home, thanks guys. Anyone happen to have that part number?Comment
I think it's 12611730160 but the autozone one is fine bruh. you'll need a deep socket or an open end wrench
That was it! I had a hard time believing it when I first looked at it. Oil was being pushed from waaay down there, uphill, all the way over the thermostat housing to the other side of the block
. Fired it up and lifted that conduit; sure enough, oil was pouring out. Replaced the sensor, topped off the oil, and I'm good to go!!
Thanks for all the help folks, it probably would have taken me a very long time to find that. Gonna degrease the engine bay today and hope there are no more surprises!
