Gas pedal
  • socalife
    • Jun 2014
    • 177
    Gas pedal
    I know the stock pedal is wired and it feels so choppy to the point where I can't rev softly without it jumping to 4k. Does anyone have experiance with electric gas pedals? I am kind of interested in installing one, I think it would be better then replacing the cable. Btw I have moved the flange at the throttle body and it's fine
  • blunttech
    • 12850
    have you lubed anything?? What you are contemplating is not better than replacing the cable, If that even needs to be done
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • haggardfab
      • Sep 2011
      • 283
      youd rather convert your car to drive by wire then change the throttle cable? LOL
      IG: haggardfab
      • AndrewBird
        The Mad Scientist
        • 11898
        Every car ever made up until fairly recently has used a cable. There is nothing wrong with a cable actuated throttle.
        As Blunt suggested, try lubing the cable first and if that doesn't fix it, buy a new one. A sticky/stiff cable will cause all kinds of problems.
        • noid
          • 1535
          Drive by wire (electrical switch) is the opposite of why someone should own an e30. A good cable will be smooth and the responsiveness should be excellent.
          Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
          Your resource to tools and tips: www.rtstools.com
          • socalife
            • Jun 2014
            • 177
            Yes I lubed it and still feels weird :/ I guess I'll try replacing it. But I didn't know most cars are still by wire
            • Mr. Tasty
              • Jul 2011
              • 3421
              Most are/were driven by cable, is what he was saying.
              2014 Alpine White 335i MSport
              (Daily Driver)
              Full Mperformance Aero
              KW V2 Coilovers
              VRSF Catless Downpipes
              • socalife
                • Jun 2014
                • 177
                Yeah, but I guess I can understand how the mechanic feel of the e30 is important
                • 15Michaeljoseph
                  • Aug 2013
                  • 1693
                  If you've ever driven an e46+ the drive by wire causes a kind of noticable delay in throttle response. don't put your e30 through that punishment.
                  --Mike
                  (OO=[][]=OO) For Life
                  • Cephas
                    • Apr 2012
                    • 878
                    --Mike
                    The same can be said for the Mini Coopers. The only way to get rid of it was to drive the car in sport mode. Otherwise i often found myself "leaning into the acceleration" without any acceleration happening. It was pretty annoying actually.
                      You need to replace the cable. Also check the bushings for the throttle rod behind the pedals.
                      • vpilarrt
                        • Jun 2006
                        • 2096
                        OP I think you're having trouble with nomenclature. "Drive by wire"% is not a cable, it's the electric throttle system
                        • socalife
                          • Jun 2014
                          • 177
                          Cable replaced, it feels fucking amazing thanks guys
