M54 crank spacer help
  • Bimmer_man
    • Jan 2013
    • 1478
    I ordered and received my crank spacer and am wanting to install it but i need to take out the little pins on the snout of the crank. Anyone got any experience removing these bastards?
    Float like a cadillac sting like a Bimmer!:)
  • 88SuperETABD
    • Apr 2009
    • 911
    Yes.. just use a flathead screw driver and pop under the "key way things" with a hammer. Theyre half moons in a sense. Heres a pic. hope it helps.
    should be same on ur m54 as my m52
    they can be reused as well if you dont munge em up too bad.
    (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
    1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
    • Bimmer_man
      • Jan 2013
      • 1478
      im trying that i guess i didnt hit the flat head hard enough. That thing is just a pain in the ass.
      • AndrewBird
        The Mad Scientist
        • 11898
        FYI, these are called Woodruff keys.
        • Bimmer_man
          • Jan 2013
          • 1478
          i feel like this is a stupid question but will i need to use those keys?
          • Chruby99
            • May 2011
            • 262
            yes the keys correspond with the groove on the dampener and crankshaft timing cog. It keeps everything lined up If you f those up you can buy those at most part stores or machine shops. Sold by grove width
