Can an '89 model use a '90 AC evaporator? They cost a lot less
  • CurrusDei
    • Mar 2014
    • 673
    I'm overhauling my AC system, part of which is replacing the evaporator.
    Is there any reason I can't use this model: $76.95
    Instead of this model: ~$140 ($120ish if you can find it without the expansion valve)
    Looks like there are a couple physical differences, but are the actual airboxes any different? I'm replacing all hoses as well so if thats a compatability issue i can just get new style lines.
    _______________________________________________
    5 Year M3 Build, In Progress
    RMT200 Retrofit
  • CurrusDei
    • Mar 2014
    • 673
    Edit - just called FCP and looked up the part on Omega. the 89 CAN use the Omega part - so there you go
    RMT200 Retrofit
    • CurrusDei
      • Mar 2014
      • 673
      Edit again. The part arrived and the newer version is slightly smaller and the hole for the temperature sensor is in a different spot. I modified mine so that it works by drilling a new hole for the temp sensor and adding some padding to give it a snug fit, but be advised it isn't plug and play.
      RMT200 Retrofit
      • Old city bimmer
        • Jun 2014
        • 1114
        thanks for posting the update
        323i MTEC1
        Z3 coupe
        E60 M5
