Aux fan resistor HELP
  • ColbsE30
    • Aug 2014
    • 35
    Where is the auxiliary fan resistor located on the 325e? My aux fan does not work and I need to trouble shoot with the resistor but don't know where it is located. Pictures would be helpful.
  • 36brua
    • 689
    The resistor should be mounted to to frontside of the elec fan in front of your radiator. it's about12mm sq x50mm l wire terminal at each end.
    check your fuse ? Good luck !
    My CA legal M60 swap
    The happening in our garage
