found a nice cat in case mine is bad
those are some attractive prices.
I'd opt for bolt-in replacement personally
got mine from Ultimate Garage
looks like i may have wasted money..
i always always always check prices on summit. not to mention their shipping costs are VERY favorable or you can pick them. i might drive to the Reno summit and pick this set up when go visit my girlfriends mom.
if i was doing a performance application and had more time/money i would.
1. cut off manifold flanges from catalytic assembly, weld in new 2" down pipes and put flanges on them where the universal dual 2" in/2" out cat can bolt up too.
2. make a test pipe for a "cat delete"
3. make an x pipe before the cat.
4. get rid of resonators
5. keep the stock muffler.
Originally posted by ptownTSIhave you even been under your car before?
Originally posted by ptownTSIthe summit cat has 2 inlet pipes and 2 outlets. read the specs about the item.
and while $89 shipped sounds better than $249 shipped, i will pay at least $250 in custom fab costs to get the universal one installed.
you cant just weld that universal cat in there. the factory cat is a humongous piece that will need to be cut out. so the shop will need to pretty much run all new piping from the resonators back which would probably cost $150. and if i was doing that much i'd just have them get rid of the resonators, put in an x pipe, and then weld up the cat.
at $80/hr for the muffler shops around here. it cost me $160 to have a cat installed with a test pipe on my jeep. flanges were put on the cat, the test pipe, the main muffler piping. that was for only a single cat, with 2 flanges.
