Wierd Choppy Vibration Whilst Turning Hard
  • Nathan
    • Apr 2004
    • 671
    Right now if I take a right turn and accelerate through it, about mid-way through the turn the left rear of the car starts to jitter as if it is skipping instead of just sliding or something. This doesn't happen if I am not accelerating in a turn. It sometimes happens on left turns as well, but it is harder to do, i.e. requires more acceleration/speed around the corner. And the noise will still be from the same side.
    Thanks in advance for any help!
    -Nathan
    PNW E30 CREW ///
  • MrK
    • Jan 2006
    • 709
    It sounds like your rear-left shock is dead. With the car stationary, push down on that corner and see how many times it oscillates. If more than once, replace rear shocks.
    This is your M20 on steroids:
    • Nathan
      • Apr 2004
      • 671
      On the right side, when I pushed down it came up, then went down a little then came to a rest. Is that more than once? The other side (left/drivers) comes up and then to rest.
      PNW E30 CREW ///
      • Brew
        • 3060
        Check your rear shock mounts, too.
        '91 318is
        • 92 mtechnic cabrio
          • 4907
          check the torque on your wheel bolts.
          no. seriously.
          I didn't, and I lost a wheel
          R.I.P 07/01/09 - 04/23/10 :(
          • Eurospec
            • 2611
            Like others have said, it could be a blown shock or a bad rear shock mount... most likely the latter.
            • Nathan
              • Apr 2004
              • 671
              Already checked wheel torque, and I just replaced the rear shock mounts a year ago..~12,000 miles.
              Any other ideas?
              PNW E30 CREW ///
              • HST
                • Jan 2006
                • 757
                Check your sway bar links, make sure that they are good / conected. My buddies rear driver side sway bar link has a tendency to come disconected, when this happens the rear end won't slide out, it just kinda skips / bounces.
                Originally posted by KingB
                Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  Yeah... I'm his buddy and I can vouch for that.. since the fucker became disconnected again all it does is vibrate like a bitch when I try to make the rear end break loose.
