sticking temperature gauge issue
  • DesertBMW
    • Aug 2011
    • 1042
    Yes I did fix the lose ground nut on the back but this is 3rd E30 that I have this issue. When car is first started, gauge will stay at cold and will require light tap on the dash then the gauge jumps from cold to normal and operates fine.
    I did attempt to replace just the temp gauge inside the cluster and I get the same result. I tested all the traces on the cluster board and it all looks great.
    Searched but I all I get is the lose nut issue.
    Edit with Update:
    Problem is with temp gauge itself. Needle inside is physically sticking to something. I did some gentle bending of the needle, now the gauge works all the time.
  • dnguyen1963
    • Nov 2011
    • 2651
    Take the board out and look at it under a magnifying glass for any broken solder.
    • BruceJ
      • Sep 2012
      • 62
      mine does the same, thinking its more of a mechanical issue with the gauge
      89 e30 white vert
      88 e30 Red vert
      2003 330i sedan
      2011 E93 335is
      2007 Z4Si (gone)
      • Delta
        • Oct 2014
        • 34
        Mine does this as well. Remove the cluster and inspect for loose connections, cracks in solder joints, and double check that nut.
