I'm having and odd issue with the central locking. I tried searching for ways to fix it here and other forums but had no luck. Anyways, the only door I can unlock with the key right now is the passenger door. I can manually lock the driver door, but if I lock both I have to unlock the passenger side first and then crawl through, which isn't too fun, so I just leave it unlocked for now.. The central locking used to work when I got the car, and then I made the mistake of trying to lock the car with the key on one of the doors. With my car, only the trunk lock will unlock/lock the doors and gas cap, but since trying to lock just one of the doors I've been having this issue.
Today I pulled out the central locking actuator that's located under the trunk lock, but pushing/pulling on it doesn't do anything. Is there a fuse blown somewhere? I'm sure the wiring is fine, since this issue was most likely cause by me messing with the door locks. Do I have to go into the doors and replace something? If anyone can point me in the right direction I'd really appreciate that.
