Stiff throttle pedal.
  • SterlingMetE30
    • Mar 2014
    • 229
    Since owning my car in March. The throttle pedal is rediculously stiff. My leg and foot are used to it. But it doesn't feel fluid. Any thoughts to make the pedal feel normal?
  • jalopi
    • 2370
    Maybe something's binding up? Try lubing the pedal linkage + throttle linkage up. If that doesn't work then a new cable'll probably set you straight
    • e30Prestige
      • Jul 2012
      • 204
      ^ What he said. I replaced my throttle cable and the difference is night and day.
      • SterlingMetE30
        • Mar 2014
        • 229
        May have to do it then. What do they run$ wise?
        • AndrewBird
          The Mad Scientist
          • 11897
          I think they are only $25 or so new, but lubing them will give the same effect usually. Try that first. Use a light oil like 3-in-1 or tri-flow.
          • E30Kop
            • Apr 2013
            • 31
            I'm not sure if it the case in the LHD models but in the RHD cars the cable runs from the throttle body to the firewall & if not tied up, will rest on the edge of the tappet cover which heats it up & from there the cable starts to disintergrate.
            I replaced mine & now it as light as it should be
            • SterlingMetE30
              • Mar 2014
              • 229
              Will do thanks guys!
