I'm planning on a 5spd swap and was wondering if I should just go with a new e30 master cylinder or if there is a upgrade cylinder I can use?
upgrade master cylinder
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None -
I assume you're talking about the clutch master? Just go with stock. Ate if you can find it, if not Febi/Bilstien/FAG are all acceptable. Same brands for the slave too.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'
