Car cranking, but not starting(Now with spark!)
  • solo318
    • Jun 2012
    • 183
    #136
    Do you have a spark plug pulled in your video?
    If not you have a compression loss on at least one cylinder.
    It's time to recheck your cam belt and do a compression test. If the DME does not see a sync signal (the plug wire with the sensor on it) It will not signal the coil to fire. If your cam timing is off then that won't happen.
    How long has it had that skip when cranking?
    • ST1G
      • Oct 2012
      • 6690
      #137
      Originally posted by spdracrm3
      so now why is the ECU not controlling the coil ,i think its time to check every pin at the ECU for correct voltage/ground /signal as something is keeping the ECU's from working ,do you have a manual that has an ECU pinout ? (ie what should be present at every pin ?)
      also worth doing a very good inspection of the tone ring for any damage/excessive wobble anything that could potentially cause a bad pattern
      I have a Bentley, I'm not sure if it has a pin out. Are you talking about on the hardness connector or the ECU pins?
      I have a timing belt kit that I need to install. I'm almost thinking I should just do that and while it's all apart inspect the crank signal giver. That would verify timing too.
      I know this to be false. I've got my other e30 to spark with a plug connected directly to the coil, this means there is not electrons going to the distributor, other wires, or the sensor wrapped around one of the plug wires.
      There is two plugs out in that video. And I know the tiring belt is on because the cylinders are moving up and down.
      • spdracrm3
        • Sep 2009
        • 959
        #138
        "I have a Bentley, I'm not sure if it has a pin out. Are you talking about on the hardness connector or the ECU pins?"
        well from what i can tell so far your getting everything you need for the ECU to be working (other than scope testing CKP pattern),as you've already swapped ECU with another working car we can eliminate that only thing left is some signal to ECU that is incorrect causing it not to work. so basically you need to find a pinout for every pin at ECU and check each with it connected and make sure every signal/ground/power..... is right
        i have a pinout but its for a 318i and im not sure how much is common between the two models, another option is to go thru the ETM and find every pin and figure out what its supposed to be but this is difficult unless you really understand FI systems and their control . a good pinout will give values for key on, key off ,cranking so forth
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • ThatOneEuroE30
          • Dec 2013
          • 8626
          #139
          Could you just try swapping motor harness's
          1991 318i 4dr slick top
          Mtech 2 turbo restoration
          • spdracrm3
            • Sep 2009
            • 959
            #140
            couple other things i thought of today , from your video with the test light ,that isnt a smart LED test lamp is it (one that shows different color for ground or power) it just seem awful bright making me think it isnt an old style incandescent bulb version which you definitely need to do this test . a logic or smart test lamp wont work properly
            i just happened to have a running 88 325iC in the shop today and have an old style Snap on test light and confirmed that during cranking it flashes distinctively (little hard to see once its running ) ,couldnt take a video though as i was on shop time ,i use this test on all other makes all the time but have never done a 325 so just wanted to make sure its a legit test and it is. on Hondas it will kill the bulb in the test light for some reason after about 10 flashes
            also you never answered if any other ring end terminals were connected to the coil (neg term) possibly causing loss of control signal? (if an alarm or aftermarket tach is connected but shorting it will kill the coil signal)
            Angus
            88 E30M3 X2
            89 325IX
            92 R100GS/PD
            • ST1G
              • Oct 2012
              • 6690
              #141
              well from what i can tell so far your getting everything you need for the ECU to be working (other than scope testing CKP pattern),as you've already swapped ECU with another working car we can eliminate that only thing left is some signal to ECU that is incorrect causing it not to work. so basically you need to find a pinout for every pin at ECU and check each with it connected and make sure every signal/ground/power..... is right Are you saying check the pins of the harness with the ECU connected, or the CPS?
              I have a pinout but its for a 318i and I'm not sure how much is common between the two models, another option is to go thru the ETM and find every pin and figure out what its supposed to be but this is difficult unless you really understand FI systems and their control. A good pinout will give values for key on, key off ,cranking so forth
              I can search for a pinout. Farbin might have one. I don't think that the 318 is the same, the 4 bangers used a different ignition system (according to the Bentley).
              I appreciate your helping me with this, I was skiing all week so I haven't looked for a pin out.
              As far as the test light goes it's a $3 auto zone special. It's a incandescent bulb, not an LED. It's really nothing fancy, just a bulb with a negative clip, and a probe end.
              The only thing that is connected to the coil is the green lead to power, and the black lead to negative. There are no other things connected to the coil. There is also no security system or any junk like that on the car.
              I can also see about finding a scope so I can test the signal. I will try with the test light on pin 15 of the coil just for kicks.
              • ST1G
                • Oct 2012
                • 6690
                #142
                Well, I found this. I'm thinking I might just go through it and test the whole harness? It doesn't seem like there is much there that I haven't already done. I'm getting suspicious of it being the signal being sent by the CPS not being correct.
                • ST1G
                  • Oct 2012
                  • 6690
                  #143
                  Testing has been done. One highly notable thing, before I jump pin 36 and 2 (ground, activating main relay), I get 11.88v (The battery is currently producing 11.98v) after I jumper 36 & 2 I get only 1v at pin 37.
                  Also, with no jumper the test light is very weak at 36, but full power at 37. But both have the same 11.88v running to them.
                  No jumper 36
                  No jumper 37
                  Results
                  • ThatOneEuroE30
                    • Dec 2013
                    • 8626
                    #144
                    Gonna have to say the 1v at pin 37 is your problem.
                    • ST1G
                      • Oct 2012
                      • 6690
                      #145
                      I have a strange feeling you're right.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        #146
                        Now it's how do you go about fixing that. My guess would be just swap out harness. For known good one.
                        • ST1G
                          • Oct 2012
                          • 6690
                          #147
                          Sounds like a lot of work. I'd prefer tracking down the issue. I am looking at some diagrams now to see what's in the mix.
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            #148
                            I just hate messing with wiring. So in my case I'd be swapping harness's aren't that hard imo. Carry on.
                            • solo318
                              • Jun 2012
                              • 183
                              #149
                              Pin 36 is supposed to have low voltage normally. It is the trigger circuit for the main relay. When you jumper 37 to pin 2 (ground) it should engage the main relay and send battery voltage to pin 37. when you jumper the pins you should listen for the relay to click. If you do not here a click then check for battery voltage at pins 30 and 86 of the main relay. If you here a click and still have no battery voltage you should jumper pins 30 and 87 of the main relay and check again for voltage at pin 37. If you have battery voltage at this point the relay is bad. If you do not you have an open on the red and blue? wire from pin 37 to pin 87 of the main relay.
                              • ST1G
                                • Oct 2012
                                • 6690
                                #150
                                If you read the chart I posted with my values you see that when pin 36 is grounded I get a clicking. When it's grounded to pin 2, or jumped to ground.
                                I've already checked voltage at pins 30 and 87 at the main relay, and I get the correct voltage! I also know that I have the correct voltage because in previous tests I get voltage from the main relay, over to the fuel pump relay, and over at the coil, with the relays installed.
                                I don't know what you're trying to say.
