Car cranking, but not starting(Now with spark!)
  • ST1G
    • Oct 2012
    • 6690
    #31
    Get that new crank sensor in and then go from there
    Yeah... I stop by the parts store. $80 I'm going to see if I can snag some from the yard that test okay.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      #32
      Yea. When I thought it was mine for the m30 I priced mine at around 100 or something. To much to pay for something that may not be the problem
      1991 318i 4dr slick top
      Mtech 2 turbo restoration
      • ST1G
        • Oct 2012
        • 6690
        #33
        Well, twist of events. I realized today at the yard I tested the harness on my car, not the sensor. So I grabbed a good sensor at the yard and come home and retested the resistance of the CPS and it tests within limits... So I don't think that's the problem.
        So, no I have no clue what the problem is. I guess I'll try a new distributor for giggles :(
        • ST1G
          • Oct 2012
          • 6690
          #34
          Talk about frustrating. I'm really just unsure where to go from here. I pulled and visually inspected the CPS. It was covered in oil and debris. I cleaned it and reinstalled, it's testing even closer to spec for resistance.
          After reinstall I'm still not getting any spark
          Here is the dirty sensor.
          Updated: hooked a spark plug directly into the coil via the coil sender wire. Grounded plug with jumper cables and go no spark. Moved the same spark plug and wire to my running e30 and got spark for days. Moved the working coil over, and still had no spark. So I think it's safe to say that my issue is up stream of the coil.
          • ///M42 sport
            • 3952
            #35
            hmm I had a similar issue...turned out to be the main relay. You mentioned the no fuel issue...look anymore into that? Fuel pump?
            • ST1G
              • Oct 2012
              • 6690
              #36
              I have jumped the main relay and that didn't solve the problem.
              Tomorrow I'm going to try a known 173 ecu
              • HennaE30
                • Apr 2014
                • 1965
                #37
                If the ECU doesn't fix it, I would start checking grounds for everything, even just a loose bolt will cause some of the dumbest things like this.
                Originally posted by flyboyx
                how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                Originally posted by Northern
                beer is my new liver cleanse.
                Henna - '84 Hennarot 325e
                Lola - '89 Schwarz 325is - being saved
                Christine - '88 Schwarz 325is - Spec E30 Racecar
                '01 White F150 Lariat 4x4 Supercrew - Daily
                Dad's '05 Interlagosblau M3
                • ST1G
                  • Oct 2012
                  • 6690
                  #38
                  If ecu doesn't do it, I think I'm going to verify the harness between the ecu and the engine bay has continuity.
                  At that point I'll start checking grounds.
                  • HennaE30
                    • Apr 2014
                    • 1965
                    #39
                    Ah yes, forgot that step. Good luck! Hopefully it's something simple and easy on the pocket book, let us know how it goes.
                    • ST1G
                      • Oct 2012
                      • 6690
                      #40
                      If it gets too expensive I might have to just go 24v :)
                      • ST1G
                        • Oct 2012
                        • 6690
                        #41
                        Update: Tried a working 173 ecu, no spark. My 173 ecu in the other car, works perfectly.
                        Soooo we can rule out the ECU.
                        • ThatOneEuroE30
                          • Dec 2013
                          • 8626
                          #42
                          Got that crank sensor?
                          • DiM
                            • May 2012
                            • 90
                            #43
                            I'm having this same issue. Cranks but no start. Replaced fuel pump/filter, cap/rotor, spark plugs/plug wires, crank sensor, coil, fpr and she still doesn't turn over.
                            • ST1G
                              • Oct 2012
                              • 6690
                              #44
                              Do you have spark?
                              • Skoobeesnak
                                • Jun 2006
                                • 132
                                #45
                                My old CPS was testing as good but the new replacement I got was bad. I would get an OEM CPS or take a known good one and try it. I went through something very similar a month or two ago. Are you getting voltage at the coil?
