i recently did a 24v swap, connected all the ac components and everything worked well for couple of weeks until apparently i started to get refrigerant loss and slightly after compressor stop engaging.
1- ref loss was from 134 filling valve adapter. it was discovered today/ removed then vacuum and refill. compressor still no go. i assume gas is ok now but compressor still doesn't engage. relay inside cabin ticks, fuse 20 is good .. I'm lost and need help narrowing the problem. car is 91 325i with m52b28 obd2 swap. compressor is e36 as well.
