Coolant temp sensor
  • SterlingMetE30
    • Mar 2014
    • 229
    Coolant temp sensor
    Coolant temp sensor. Which oth the thermostat sensors is the cts I have looked online already. Nothing. Noob question I know.
  • 101
    • Jul 2011
    • 764
    Assuming this is an "I" car, on the thermostat housing are two sending units:
    - The single wire one is for the temperature gauge on the dash.
    - The one with two wires is for the car's engine computer (DME).
    If its an eta there are 4 ...
    101
    The E30 collection:
    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
    1987 325is - Delphin / Black Sport (son #3's)
    1987 325i Convertible - Triple Black
    1989 325iX Coupe - Diamondschwarz / Black Comfort
    1990 325iX Coupe - Sterling Silver / Grey Sport
    1981 Fiat 124 Spider 2000 - Green / Tan
    1998 Volvo V70 GLT - White / Tan
    1998 Volvo S70 T5 manual - White / Taupe
    2001 Ford Windstar - Silver / Grey (parts hauler)
    2006 Lexus GX470 - White / Tan (tow rig)
    • SterlingMetE30
      • Mar 2014
      • 229
      I was told it is an e engine. It has been replaced. But I only have two wires..?
        • 37833
        When in doubt, post a picture.
        Grover Beach, California
        BimmerHeads.com
        • SterlingMetE30
          • Mar 2014
          • 229
          Hope it loads
          • ak-
            • 12422
            Originally posted by MR 325
            When in doubt, replace all of them
            1991 325iS turbo
            • SterlingMetE30
              • Mar 2014
              • 229
              Mine is the double wire sensor. Can't seem to find the part at the stealership or autozone cause they gave me the wrong one.
              A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
              • 101
                • Jul 2011
                • 764
                It's unclear from your post exactly which of the four sensors you are thinking about replacing. Three of them have double wires. What are the symptoms you are trying to address?
                http://www.realoem.com/bmw/showparts...59&hg=11&fg=35
                This help at all?
                101
                The E30 collection:
                • SterlingMetE30
                  • Mar 2014
                  • 229
                  I am trying to address rough idle. Cold start and warm idle. And maybe 12 on the diagram.
                  • Chuck C
                    • 104
                    Call or stop by a CARQUEST store with your BMW part numbers. CARQUEST is part of the Worldpac empire, and some things that are NLA from BMW are available from Worldpac.
                    • SterlingMetE30
                      • Mar 2014
                      • 229
                      Sweet thanks! I will have to check it out.
                      • 101
                        • Jul 2011
                        • 764
                        Got it.
                        There are tests for each of those sensors in the Bentley manual. Here's what I'd recommend:
                        1) If the temperature gauge on the dash looks to be reading correctly - I'd leave that single wire sensor alone. It does nothing but operate the gauge.
                        2) Test the "45'C" sensor (the one with the spade connectors. Its a simple on-off switch. If its cold, it should be an open circuit. If it's warm, it should have continuity across the terminals.
                        3) Use the Bentley manual to test the Thermo time switch. If this switch is bad the problem is usually more one of hard to start when cold or flooding when warm.
                        4) Replace the coolant temperature sensor. Its cheap enough.
                        For rough idle, the rest of the crew here will tell you to run a smoke test. These intake systems leak everywhere when the gaskets get old and the rubber hoses harden.
                        Full diagnostics at the ECU connector using the instructions in the Bentley manual is also a good idea. That was you can check all the sensors AND the wiring to the ECU at the same time.
                        On my eta, I changed the 45'C switch ($36) and the coolant temperature sensor ($17). I got them both at Bavarian Auto. Make sure you get the correct coolant temperature sensor as the one for the eta is different than the one for the "i" cars.
                        Good luck!
                        101
                        The E30 collection:
