coding plug question 5k vs 7k
  • jayuuey
    • 414
    First off, apologies for another coding plug question. I've searched but there are so many different posts with conflicting info.
    For later style clusters VDO/Motometer, does the coding plug differentiate m20 ETA (5k redline) vs I (7k redline) or is it irrelevant since they are both 6 cylinders?
    My 87 eta cluster began acting up again so i swapped in a working 88 325i cluster (no coding plug or tach changes just a direct remove/replace). The cluster appears to be working but at 5k rpm, it seems like it wants to rev some more.
    Thanks.
    • 37828
    Yes the Eta and i coding plugs are different.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • jayuuey
      • 414
      Do you only swap plugs if you swap tachs? Or do I need the eta plug on my 7k 325i tach?
      Sent from my SCH-I535 using Tapatalk
      • AndrewBird
        The Mad Scientist
        • 11898
        Pretty sure the coding plug needs to match the tach.
        • jayuuey
          • 414
          Ok so i can keep my set the way it is now, which is 325e with a 325i tac and coding plug.
            • 37828
            Exactly.
            Grover Beach, CA
            www.BimmerHeads.com
