fuel or brake line?
  • long tall eta
    • Jul 2010
    • 1536
    fuel or brake line?
    guys, i hope i didn't waffle my self. putting the car up tonight to change the lower rad hose the jack wasn't centered on the frame rail and she slipped off. it came down and the jack pinched the metal line that runs along the OUTSIDE of the frame rail. what line is this. the car is a 87 e automatic. she runs fine at least for the 20 miles that i tested it. is this a fuel or brake line?
  • Mr. Tasty
    • Jul 2011
    • 3421
    A single line is a fuel line. There will be 3 lines in close proximity, and those will be the brake lines.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • long tall eta
      • Jul 2010
      • 1536
      is there more than 1 fuel line running to OR from the engine? the line looks to be totally crimped, but the car is running fine even at high speed. if it is a fuel line, can the bad section be cut out and compression fittings used to splice in a new section?
      • 101
        • Jul 2011
        • 764
        Negative.
        The SINGLE line running on the outside of the frame rail is for the fuel tank evaporative emission control system (charcoal canister).
        On the INSIDE of the frame rail are three lines ... the smallest diameter one is the rear brake line, the other two are the fuel supply and fuel return lines.
        101
        The E30 collection:
        1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
        1987 325is - Delphin / Black Sport (son #3's)
        1987 325i Convertible - Triple Black
        1989 325iX Coupe - Diamondschwarz / Black Comfort
        1990 325iX Coupe - Sterling Silver / Grey Sport
        1981 Fiat 124 Spider 2000 - Green / Tan
        1998 Volvo V70 GLT - White / Tan
        1998 Volvo S70 T5 manual - White / Taupe
        2001 Ford Windstar - Silver / Grey (parts hauler)
        2006 Lexus GX470 - White / Tan (tow rig)
        • long tall eta
          • Jul 2010
          • 1536
          the hi lighted circle is the line and location of the damaged area. which line is this? fuel, vent, or brake?
          line by robert_elliott54, on Flickr
          • long tall eta
            • Jul 2010
            • 1536
            Originally posted by 101
            Negative.
            will i be ok running with this line being crimped to the point where i don't think it's operational?
            • 101
              • Jul 2011
              • 764
              You could potentially have some fuel smells if the fuel tank system has an otherwise good seal and the fuel gets warm and expands. It's not an urgent repair, however, especially with winter upon us.
              You might want to price up a new, pre-bent metal line from the stealer. By the time you F around with cutting, flaring and connecting what is probably a fairly rusty line it would be far easier on you.
              101
              The E30 collection:
              • long tall eta
                • Jul 2010
                • 1536
                thanks 101
                • 101
                  • Jul 2011
                  • 764
                  That's definitely the vent line in your picture. The vent line fr my IX was around $16 (somewhat discounted from the BMWMiniPartsStore).
                  And WOW - that underside is CLEAN! That is NOT what I expected from a Jersey car.
                  101
                  The E30 collection:
                  • Andyp
                    • Aug 2014
                    • 31
                    My my lines are fairly rusty and I was going to replace them..
                    However, when I went to the dealer, he said the lines would not come pre bent, so I didn't order them. Can anyone confirm this? I don't want to order them unless they are pre bent
                    • long tall eta
                      • Jul 2010
                      • 1536
                      not my car, pulled that pic from r3v after googleing (e30 undecarriage image) although mine is quite clean and absolutly rust free.
                      • 101
                        • Jul 2011
                        • 764
                        The fuel and vent lines I purchased for my IX this past summer were indeed pre-bent.
                        Brake lines are NOT - but I understand that they used to be. I think that's where the confusion comes from.
                        101
                        The E30 collection:
                        • long tall eta
                          • Jul 2010
                          • 1536
                          does anybody have a pn for this line? real oem isn't that clear on which one i need.
                          • Andyp
                            • Aug 2014
                            • 31
                            Thanks for the info! I'll have to ask the dealer again
                            • 101
                              • Jul 2011
                              • 764
                              For an 86, it should be this one. The second part number listed for that pipe would be on a SuperEta. I would reconfirm with the dealer just to be sure.
                              Description
                              Vent pipe
                              Supplement
                              8X0,7X2985
                              Qty
                              1
                              From
                              Up To
                              09/1987
                              Part Number
                              16131177466
                              101
                              The E30 collection:
