I cant seem to get power to my windows, my blower motor or a bunch of other things. It all stems from the Load Reduction relays. Neither K5 nor K7 close passing power to the circuits. It seems as though the pin 86 ground does not actually ground. If I short pins 30 and 87 everything works without a problem. There is a green/black wire that comes out of the 86 pin (ground). Has anyone had a problem with this relay not closing? I have power on the relay pin 85 and if I only have one relay in I can get it to close sometimes but not if I have both relays in (k5 and K7). Where is the ground for these wires?
I shorted pin 86 straight to ground and it blew fuse 10, I belive? Anyone have problems like this before?
