whats goin on here, any idea's??
idle goes to 2000 when i push a/c button
I've had that happen to me when I turn the throttle screw a bit too tight. The idle speed increase circuit then causes the idle to jump all the way to 1800-2100 with the a/c on, instead of around 950 where it should be. If your current idle is any higher than 750-800, loosen the throttle screw.This is your M20 on steroids:Comment
