Under the global settings of the SMT-6 it allows you to set a "0" point for the fuel. Which i assume is so you can dial back the entire fuel map for bigger injectors. My question is, how much should i dial in back for 30# injectors so it would be giving the same amount of fuel as the stock 14lb injectors. I can then begin to tune for the extra fuel from there.
