Good Call!!!! Change the timing belt!
  • Maluco
    • Oct 2005
    • 6572
    As some of you guys know, I bought that 90 325is not too long ago and decided to go ahead and change the timing belt for good measure (a few other things as well) Well..... the belt was just about ready to give in, the teeth were actually coming off the belt!
    Do you know what condition your timing belt is in?
  • Mastrcruse
    • Sep 2005
    • 5340
    The recent owner of mine replaced mine in the price of what I bought the car which was cheap for what it should have been. But bros car just hit 160,000 and hasn't recieved a change...maybe time to get one.
    • delatlanta1281
      Dart Master
      • Mar 2006
      • 10317
      Maybe????? Uhhhhhh yeah, get one. I did min 500 miles ago, I do them religiously. You have to with our cars, they don't take too kindly to timing belt failures.
      Yours truly,
      Rich
      you kids get off my lawn.....
      • Maluco
        • Oct 2005
        • 6572
        the life on them are like 80K, right? but if you don't know when it was last changed, inspect it ASAP!
        • James Crivellone
          Head Janitor
          • 6301
          60K, I replace at 50k
          • Maluco
            • Oct 2005
            • 6572
            thanks for the correction, my odo is out so I have to sit down and calculate more or less what I drive every month...
            • Tangent
              • Mar 2004
              • 476
              I was planning a 50k change cycle when mine broke on me. At 39k
              • Maluco
                • Oct 2005
                • 6572
                ouch! 39K??? So is that the car you are parting out?
                • Tangent
                  • Mar 2004
                  • 476
                  Nope, the one I'm parting out is the head donor. :p I just pulled the head off the 88 which broke the belt and found no other damage, so I'm swapping the 89's (the one getting parted) head on instead of buying new valves, a rocker arm and going through all that work... I think mine is just an unlucky freak having the belt break that early though. I hope...
                  • silversleeper
                    • Mar 2005
                    • 2032
                    on the topic of timing belt failure... if a belt were to skip a tooth or so, what would the symptoms be? i just got home and on the way i r3ved her a little (i was cruising in third near redline, but my tach recently went out, and i think i may have overrevved the motor). so, now the engine feels like its running on 5 cylinders... and if you rev it up, u hear a loud pop which sounds like its coming from the intake mani (backfire? or bent valve? i hope not the latter)
                    Claus Luthe is my hero.
