Water leak
  • SterlingMetE30
    • Mar 2014
    • 229
    Water leak
    I have water pooling in the passenger footwell. Hasn't been raining or leaking anywhere that I know of. Possible heater core?
  • turbo55
    • Jul 2014
    • 223
    Soak some of it up with a clean paper towel. Then dip another clean paper towel in the coolant reservoir. If the two colors match, you know its coolant.
    • spdracrm3
      • Sep 2009
      • 959
      if its clear fluid its possible the AC drain is plugged/misrouted in the HVAC box (have you been running the AC during defrost?) AC will act as an air dryer and the resulting fluid has to be able to drain out, the drain is right under center and drops out of tunnel above transmission
      Angus
      88 E30M3 X2
      89 325IX
      92 R100GS/PD
      • SterlingMetE30
        • Mar 2014
        • 229
        No I haven't been using it to defrost. My ac pump doesn't have a belt on it atm. I will soak some up and see. Doesn't smell like antifreeze tho. I run mostly water anyways since it hardly ever freezes where I am at.
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          It's probably coming from the "elephant trunk" in the engine bay. Take this fitting off, clean it thoroughly and make sure there are no blockages. You should also pop off the wiper cover/grill thing and clean out the space behind it.
          • SterlingMetE30
            • Mar 2014
            • 229
            My elephant trunk looks to be removed.
