AFPR Malfunction Question
  • Saul325is
    • 819
    Ok, so I basically installed a fuel pressure gauge, and the gauge read 37.5psi with stock FPR, then I installed an AFPR, adjusted it to 37.5psi, and after a drive my fuel pressure reads 25psi, sometimes it reads 60psi also. Do I just have a fautly AFPR? It's a bav auto AFPR by the way.
    -Saul
    Saul
    01 330ci Daily Driver
    89 332is Auto-x Friend
    95 M3 *SOLD*
    87 325is *SOLD*
  • Jordan
    • 12916
    Are you using BavAutos rising rate FPR?
    https://mtechniqueabs.com/
    • Saul325is
      • 819
      I have no clue, is that the adjustable one?
      Saul
      95 M3 *SOLD*
      87 325is *SOLD*
      • Jordan
        • 12916
        No.
        Is your stand alone, or does it mount entirely to the fuel rail?
        • Saul325is
          • 819
          it mounts where the stock FPR mounts, dirrectly bolt on..
          -Saul
          Saul
          95 M3 *SOLD*
          87 325is *SOLD*
          • DaN
            • 1265
            Where are you measuring fuel pressure?
            You have the vacuum line connected right?
            You know fuel pressure is supposed to rise when you give it gas, or lose vacuum, right?
            Have you checked for leaks?
            • DaN
              • 1265
              Is this what you have?
              "Get more power and better throttle response from your BMW. This adjustable rising rate fuel pressure regulator enriches the fuel mixture as you accelerate to increase power and improve mid-range throttle response. Maintains stock fuel mixtures at idle."
              • Saul325is
                • 819
                I'm measuring my pressure through a pressure gauged that I had tapped in after the regulator. I have checked for leaks, none. I do know that the pressure rises when I apply gas. But the thing is, It fluctuates at idle somtimes. I mean when I start my car when its cold, it takes a while to get up to the pressure that I had set. And after I do like a 30 minute drive, I open my hood and sometimes it reads 50psi, and sometimes 25psi, when I had allready set my AFPR to 37.5psi. It's not the guage, because when I had my stock FPR and tapped in my gauge, ti read 37.5 psi like normal. From what I have heard, there might be a leak in my vaccuum line?
                And yes, that is the AFPR that I have above...
                Thanks,
                Saul
                Saul
                95 M3 *SOLD*
                87 325is *SOLD*
                • Jordan
                  • 12916
                  Last I check, that isnt not a AFPR, it is just a RIsing Rate FPR.
                  From what you said it is working as intended, but its owner is just dumb.
                  • Saul325is
                    • 819
                    No, it IS an AFPR, its a rising rate AFPR. Hell, if I can adjust it its an AFPR, which I can.
                    Saul
                    95 M3 *SOLD*
                    87 325is *SOLD*
                    • Jordan
                      • 12916
                      look, that is not an adjustable FPR. it is just a rising rate fpr with idle adjustability. as you said eariler, you have no clue.
                      it is working as intended.
                      • JRowe
                        • 352
                        The problem is the location of your fuel pressure gauge. You need to measure before the regulator. By placing the gauge after the regulator, you're basically measuring the fuel pressure in the return line, not the fuel pressure at the injectors. Also, your fpr is a rising rate fpr with an adjustable initial setting.
                        • Saul325is
                          • 819
                          Thank you, so true....The location of the gauge is allright, because when I did have my stock FPR, it read 37.5psi like normal...Overall I found out that there is a very minor leak in my vaccuum line to the rising rate afpr, thats what is causing the problem sometimes. Thanks for your help guys...
                          -Saul
                          Saul
                          95 M3 *SOLD*
                          87 325is *SOLD*
                          • DaN
                            • 1265
                            -Saul
                            No, the location of the gauge is not alright, if you know how a fuel injection system works you'll realize that the pressure before and in the fuel rail is regulated.
                            If you install the gauge on the return line coming off the regulator, you are just measuring the pressure of whatever the regulator dumps to maintain correct pressure in the rail.
                            So install your guage in one of the lines coming into the fuel rail, near the fire walll.
                            You will probably find that your pressure is way out of wack.
                            • Saul325is
                              • 819
                              -Saul
                              Nah, the guage is installed right, it is on one of the lines comming into the fuel rail. I just got confused from the different areas where fuel is being let in and let out.. Sorry.
                              -Saul
                              Saul
                              95 M3 *SOLD*
                              87 325is *SOLD*
