Fog light wiring using existing switch
    just picked up some OE fog lights and was wondering if i can install the lights and have them work without the 2 button switch, just using the existing single fog switch.
    does any one have a wiring diagram?
    ^ you want to go out and get a haynes manual for its wiring diagrams. You can use the single button switch but then you'll lose your rear fogs, unless you wire the switch so it turns on both front and rear. But look into the wiring diagram to see how to do it... you may need to run an extra wire through the firewall from the switch and add a K8 relay for your front fogs. It depends what you already have set up.
      thanks for your help, i just spoke to the guy i bought the fogs off and said he forgot to give the double switch to me, so guess i wont have to stuff around with it now.
