e30 VDO cluster Odometer gear install trouble
  • R1ckM
    • Jan 2013
    • 217
    I bought a set of odometer gears from garagistics, they came in today. I promptly installed them per the instructions off their site.
    Tried it out later and the odometer isn't working still. Any suggestions on what I am doing/did wrong here?
    Out of the 3 old gears the smaller one and one larger one were broken. So I highly suspect that was the issue.
    Took the seal bearing/ring off the small sprocket before putting the new one on.
    Put them back in reverse order with the "spacer" as well.
    The small sprocket is a tight fit on the rod, doesn't seem to go down far as is should? (still lines up with teeth on larger cog though)
    Here is a short video of the cluster/install.
  • stopsign01
    • Nov 2014
    • 113
    It looks to me like the gear on the right is upside down? Shouldn't the small gear on top be interacting with the large gear on the left?
    • R1ckM
      • Jan 2013
      • 217
      Clearest pic I could find on the garagistic diy:
      Just found this so maybe I will go ahead and flip the gear on the right. Great suggestion!
      • garagistic
        • Apr 2011
        • 1712
        You are correct. The gear is upside down.
