I've read here on the forums that DME pin 1 should be an open circuit (more than 1k ohms) when probed to ground. My DME pin 1 has like 4v on it when I do this (and no resistance).. what's up with that?
Also, when checking for voltage at the coil, it isn't quite battery voltage... while in operation, voltage on the negative side of the coil is like 10v. This is switched to ground by the DME correct? should this be battery voltage?
Engine runs rich and misfires like crazy, hardly stays running and any bit of throttle will choke her out. Been going through the steps, just trying to figure out these couple quirks before moving on. If I connect a spark tester to one lead at a time while the engine is running the spark seems strong and blue... but intermittent. Can anyone shed light on these couple of things? I have cleaned all battery terminals and wiring from the battery to the little junction box and check to make sure the fusible link is working properly.
