Fuel Expansion tank?
  • iansane
    • 1342
    What does it do? Is there a good way of re-routing the hoses from it? Possible to delete?
    84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
  • dnguyen1963
    • Nov 2011
    • 2651
    Gasoline has pretty high vapor pressure. VP is dependent on the temperature. The volume (vapor) inside your gas tank will expand/contract with the rise and fall of outside temp. The vapor needs to have some place to go and that is what the expansion tank is for. I would leave it alone. Where would you re-route it to?
    • iansane
      • 1342
      Thank you for the info. Sounds like a needlessly complex system.
      The expansion tank itself isn't a huge deal but I'm trying to move/delete the weird metal tube that runs through the passenger compartment.
      • Bearmw
        • 1323
        I got rid of the charcoal cannister, evap valve, and engine compartment hoses but left the expansion tank and vent hose that I coiled a couple times and added a cheap mini gauze filter on the end. This is hidden under the plastic shield.
        I had no need for an evap system on my engine.
