Car keeps dying after releasing throttle
  • E21newb
    • Feb 2014
    • 18
    So I am in Iowa and we had a snow storm. But I've drove my e30 in colder weather and this problem has never occurred before. When I drive and release the throttle the car stalls. But when I start the car it starts normally. So as long as I keep stepping on the throttle it does not stall. I do not know what is causing that to happen. Really need help. This is my daily driver.
  • dnguyen1963
    • Nov 2011
    • 2651
    Check your fuel filter/pump and make sure that the car has proper fuel pressure. Check your FPR. Check for vacuum leaks.
    • ST1G
      • Oct 2012
      • 6689
      Correlation is not causation.
      What year is it? does it have an erratic idle?
      • spdracrm3
        • Sep 2009
        • 959
        sounds like a sticking idle control motor ,remove and clean it ,then lightly oil with WD40
        Angus
        88 E30M3 X2
        89 325IX
        92 R100GS/PD
        • E21newb
          • Feb 2014
          • 18
          It's a 1987 325is. My idle looks fine, doesn't move much. But when I listen, the car sounds like a damn tractor. I don't see any leaks of any kind(unless I didn't look hard enough). The vacuum lines all look fine. Not driving my E30 makes me sad :(
          • dnguyen1963
            • Nov 2011
            • 2651
            You need to put some love into your car...starting with doing a smoke test.
            • agent
              Vice Grand Pubaa
              • 7960
              My vote is for the bitch tube.
              Originally posted by kronus
              • E21newb
                • Feb 2014
                • 18
                Which tube? I think the car is being a bitch right now. I must not be treating her right.. Or she's PMSing.
                • E21newb
                  • Feb 2014
                  • 18
                  Okay, so I just tried messing with it again. The first time I started it, it died. Second time it stayed on but idle was slightly moving around. I turn it off. Start it the third time, same thing. Then I press the gas a couple revs and let go. Then it just dies. I looked at the hoses and made sure the plug wires were tight. There is also a very strong smell of gas. But I see no leaks..
                  • efficient
                    • Feb 2012
                    • 3312
                    BItch tube is the tube underneath the throttle body/intake manifold
                    • agent
                      Vice Grand Pubaa
                      • 7960
                      ^ Yep. So named because it's a bitch to change without removing the intake manifold - but it's possible.
                      Opie, sounds like your car is doing almost exactly what mine was doing when that tube had a large crack in it - which was not visible until I replaced it. If you have a helper, have them start the car while you apply pressure/weight to various places on that tube. If the car runs better depending on where you're mashing, you found the problem.
                      Note: If you read/see a suggestion to spray brake cleaner on your intake pieces and/or vacuum hoses, that test did not help me diagnose this issue on my car (also an 87 iS FWIW).
                      • E21newb
                        • Feb 2014
                        • 18
                        Okay so I didn't have anyone to help me out. But I tired to locate the tube. I THINK I found it but not sure. I tried squeezing it and even tried to mess with it to see if I can remove it. Nothing. Is it the vertical tube that has ridges on the bottom of it? Going to the head?
                        • bmwcarnute30
                          • Jan 2015
                          • 123
                          the "bitch tube" runs from your valve cover across to the other side of the intake manifold. im having a the same problem. will do a smoke test tomorrow and check for leaks
                          • cgk_iii
                            • Dec 2012
                            • 616
                            year? Motor?
                            • agent
                              Vice Grand Pubaa
                              • 7960
                              Originally posted by cgk_iii
                              year? Motor?
                              It's a 1987 325is.
