Ok I just installed a piggy back computer into my 85 325e, but the problem is the rpm display on it is going crazy, it jumps all over the place, the tach is staying where it should and reading the correct rpm's. I connected the rpm input for the piggyback to the black wire pin #1 on the c104 plug by the ecu. Any ideas why it's not reading correct and jumping all over the place?
RPM's going crazy
for the AFM wire yes, I figured it out, my Plasma booster and the Apexi wern't playing along together nicely. I undid the ground for the booster and grounded it to the frame instead of the coil, and now it reads just fine. I just have to find a MAF(i damaged the one I had installing a temp sender) and buy a wideband o2 and I'll be good to go.85 325e 2.7 ITB'd stroker
