I have an 85 323i with an M50 swap that is producing very little heat. Just replaced the heater valve and heater core and bled it numerous times but no changes. The top hose going into the core gets hot but the bottom hose stays cool. Could the hoses be mixed up? Could it be a weak water pump? Car is not overheating and temp is right in the middle.
E30 Swap Low Heat
I just replaced all the hoses on my 1991 325iC. For my car, the coolant inlet (HW to the core) is the lower pipe on the firewall. Not sure if it makes a difference if you reverse the lines. Or your heater valve may not be opening up correctly. Or there is air in the core. Let us know what you find.Mike
Cary, NC
Current Rides
1991 325iC - For Sale
2006 M3 Cabriolet
Past Rides
2000 323i Touring - Daily Driver
1994 325is (S50) - Fast Car
1998 Z3 - Fun Car
1986 325e (i engine conversion)
1969 Mustang Mach 1
yea try to swap the lines and see if it makes a difference. i cant remember which hose went where when i had a swapped e30. also not sure if your car has the extra valve that goes to the heater core hoses. if so that may be clogged. let us know what happens as well. good luckOriginally posted by evandaela car is a car. call it a dildo, i'd still drive the hell out of it.
