I think my alternator is crapping out because my voltage is only around 13.6 should it be up around 14.0-14.4?
what should voltage be at while idling?
use a digital volt meter (DVM) to test at the alternator, then check the battery voltage. You may be suffering from power cable loss.
And, no, I meant he should be seeing 1500 volts at idle...
sheesh...you kids!
LukeComment
It should be in the high 13s. If you're hitting 14s you are overcharging, which is not a good thing either.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
14.4 @1800 is typical of most charging systems. Remember, the alternator's job is to overcome the voltage at the battery...ANYTHING over the batteries' static voltage is adequate to charge. With headlights, heater, stereo, wipers, rear window defog, etc. on, you will need more.
GL!
LukeComment
