Cold start issue
  • Colo6645
    • May 2013
    • 12
    Cold start issue
    Hello r3v,
    Long story short, after leaving the car seating outside during the weekend I started it today (30 degrees outside) and started idling weird and eventually it died/stalled. (Refer to video, I'm using tapatalk, hopefully it uploaded correctly. )
    It's done it before and what I end up doing is maintain RPM with the gas pedal and basically drive off and after a minute or so of driving it doesn't stall. After it fully warms up I drives fine.
    Thing I know is bad: bitch tube o-rings oil/vacuum leak.
    Any recommendations would be greatly appreciated.
    Car is a5 speed 1987 325IS.
    THANKS in advance.
    Sorry, we couldn’t find that page
  • dnguyen1963
    • Nov 2011
    • 2651
    Fix your vacuum leaks would be the first priority.
    • Victor_PR
      • Jun 2011
      • 296
      Agree with the vacuum fix recommendation. Let us know what you discover.
      Sent from my iPad using Tapatalk
      Victor
      Rides...
      E30 325i - 1990
      F30 328i - 2014 (DD)
      F25 X3 - 2016 (Family car)
      1974 - 2002 (The ruler of the stable) SOLD
      • Colo6645
        • May 2013
        • 12
        Thanks for the suggestion. Once the weather gets better I'll start by fixing the vacuum leak. I'll report back.
        • Navarone
          • Jun 2014
          • 935
          Mine did that after I did the penny trick to bypass the ICV. Now when I start I have to hold the down the gas pedal a little so it idles above 1k for about 10-15 seconds depending on how cold it is. After that it idles fine.
