Power steering help!
  • rs4pro3
    • 5808
    Ok lately I've been getting a terrible creaking from my Power steering. Well today we did a groupd drive and I check it out, come to find out when the creaking happens the whole Power steering pump LOCKS up. Sitting in a parking lot or moveing slowly and if I turn the wheel either direction There is a Terrible metal on metal screeching sound. Fluid is topped off, any ideas. I've got a spair pump so I'll probally just replace it.
    85 325e 2.7 ITB'd stroker
  • DaN
    • 1265
    Are you sure it's a metal on metal sound, and not the belt squealing???
    Check the belt tension..
    Has the pump ever been ran low?
    If you have a spare pump you're in good shape.
    • rs4pro3
      • 5808
      Yes I'm sure it's not the belt squeling, completly different sound. belt tension is good, brand new belt, never run low.
      • DaN
        • 1265
        No choice then, change out the pump. 8)
        • rs4pro3
          • 5808
          Ya I'm almost positive it's the pump. I just cut the belt and tried it out and no creaking. I may just remove the pump completly and pack the lines with grease Like i did to my 318i, I'll see how it drives when I go back to class tonight.
