M30 Fan clutch?
    M30 Fan clutch?
    So my fan clutch doesnt lock up totaly when you rev car, and you can almost stop it with your hand so obiously I need a new one. I was looking at getting one from BMP. How hard are they to install just the 4 bolts on pulley then screws on clutch? Or is it worse?
    Summer '85 E24 635csi Winter '88 E30 325iX, I lose 25% of my hp before I even turn the key.
    You have to take the big nut off the end of the water pump. 32mm, reverse threaded. You can then pull the whole fan out and change teh clutch outside.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
      Get a 32mm wrench from a bike shop, you need a thin wrench to get in there (as recommended from another thread here). Others have had a tough time getting the bolt loosened, but mine just came off like it wasn't fully tight. YMMV.
