Replacing Front Convertible Seal - Advice Please
  • mcaden
    • Jun 2011
    • 164
    I plan to replace the front convertible seal (the $180 one that wraps around the front and side windows) on my E30 sometime this spring [see: part no 54318100908]. I have reviewed this thread that discusses (near the end) replacing the seal and using sealant and it raises a few "how to" questions for me, see: http://www.shareaproject.com/pages/p...,p,217,00.html.
    1. Does the seal simply pop in and out of the channel or does any trim need to be removed from the frame?
    2. The thread mentions putting a bead of sealant on the frame before inserting the new seal? Did you do that? I will also make sure to get the corners, as mentioned in the DIY thread.
    3. Which sealant did you use? Permatex 16B? A different Permatex? 3M Product 08008? Something else?
    4. Any other tips to make sure the process is successful?
    Thanks, Marc
  • fight4life28
    • Apr 2014
    • 821
    you can also adjust the top if your seal isnt tight enough. I think its pretty difficult to put in the channel with the sealent or what ever plan on useing. verts always seem to have issue's when its raining cats & dogs outside and the car is just sitting there. I don't have any issues driving in a hard rain. Dripping in the corners (still trying to figure out what I can do but I think im going to buy a new seal soon.
    -I would seal the corner seals with the same sealent while your there.
    -adjust the top if needed
    -check the latche where you keep top down make sure there not worn out (metal wise)
    -rods arnt broken and what not. (I had one and caused me issues)
    • fporro
      • 1860
      I'm swapped top's once, so will try to lower frame height by removing some shims. My window it's all of the way upland there's a still a visible gap., btw ... slpish-splas in frame rails ? see this ...
      • fporro
        • 1860
        I've swapped top's once, so a bit familiar with mounting points, will try to lower frame height by removing some shims.
        My window it's all of the way up and there's a still a visible gap., btw ...
        splish-splash in frame rails ? you know there's water in there, what to do ?
        watch this ...
