CAR NOT STRATING! HELP! ****video****
  • blizake500
    • May 2014
    • 424
    I was driving my 1991 325ix and I ran it out of gas early that day. I rolled in gas station and filled it up. Then the check engine light came on. I drove around all day got home and let her sit. I was going back out and i started it and it sounded like the motor was dry then it just gradually cut off on me. What do you guys think this is? Here is
    link to video:
  • GT BMW E30
    • Nov 2008
    • 2491
    The pump possibly ran hot due to low gas. Bang on top of the fuel pump as you try to start crank it.
    • blizake500
      • May 2014
      • 424
      Will this cause the engine to sound dry?
      • mitchlikesbikes
        • Dec 2013
        • 858
        check your fuel pump relay/fuse and also see if you have power at the pump. if you do have power and it still doesn't start then you probably just toasted the pump.
        IG: @mitchlikesbikes
        • blizake500
          • May 2014
          • 424
          will this cause engine to sound dry?
          • Das Delfin
            • Sep 2014
            • 2293
            can you hear the fuel pump when you turn the key to on?
            • dnguyen1963
              • Nov 2011
              • 2651
              It sounds like you get no fuel into the engine. Your pump is probably toasted.
              • Exodus_2pt0
                • 5943
                Check if your fuel pump is running.
                No?
                Find the fuel pump and unplug it. Connect a 12v test light to the two wires and turn on the ignition. This will cause the fuel pump to prime, and the test light should be energized for a few seconds. Does the test light come on?
                Yes?
                Replace the pump.
                No?
                Check your fuses and relay.
                No E30 Club
                • Peelsbimmer
                  • Dec 2012
                  • 178
                  The exact same thing just happened to me.
                  My fuel is good, I took off the hose going to the fuel rail and tried to start the car and gas came out. My spark is also good, but the car still won't turn over. All of my fuses were good.
                  Holy shit did you even read this post before you posted?
                  http://www.r3vlimited.com/board/announcement.php?f=156
                  This thread sure sucked last night. It just plain sucked. I've seen threads suck before but this is the suckiest bunch of sucks that ever sucked.
                  • TYBG
                    • May 2012
                    • 143
                    Sounds like your fuel pump went out. When they are not submerged in fuel they work harder then they should and it can cause premature wear on the part if it happens enough.
                    • blizake500
                      • May 2014
                      • 424
                      Timing belt broke
                      • ST1G
                        • Oct 2012
                        • 6690
                        Originally posted by blizake500
                        Timing belt broke
                        Ouch. I feel your pain.
