Acting Like a Dead Battery...Ignition Switch Bad?
  • Silver Wagon
    • Jun 2014
    • 184
    back story:
    i haven't been driving my E30 for a few months now. i have been planning on replacing my oil filter housing gasket. i have degreased the engine and don't want to get more oil on it before i replace the gasket.
    in the meantime i got a new front valance and installed it. while doing so i noticed that when i put my key in the ignition and turn it to on, nothing happens, no lights anywhere, nothing. i did this so i could turn the wheel to gain access to bolts for replacing the valance.
    since its been a little while i assumed the battery was dead, no biggy. i left the key in the on position and continued to replace the valance. while doing so, i noticed some music playing. i looked inside the car and all dash lights were on and the radio was playing. as everything should do.
    clearly the battery isn't dead. my only thought is the ignition switch is going bad. is this a good assumption?
  • dnguyen1963
    • Nov 2011
    • 2651
    Maybe or maybe not. Since you are working on the valence, you might have disturbed the ground connections.
    • Silver Wagon
      • Jun 2014
      • 184
      there's no ground wires near the valance.
      • dnguyen1963
        • Nov 2011
        • 2651
        Check your grounds. Almost everyone that works on the body of the car swears that they did not touch the grounds. It is the first thing I check when there is electrical problem.
        • 330SMG
          • Feb 2007
          • 172
          Check the wiring coming out of the ignition. PO had put 3 but connectors in a row on one wire making me think switch was bad. Soldered in good wire no more issues.
          1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
          • Silver Wagon
            • Jun 2014
            • 184
            here is some more back story.
            its a 91 318is
            bought it from a lady that used it for a bumper car. its got some dings and dents.
            the power came on while the valance was off the car. that would mean all bolts i took out were still out. if there was a ground disconnected it would still have been disconnected and nothing would have worked. also, the entire car had no switched power, that could have only been achieved by disconnecting the battery or something not letting the ignition flow the necessary power.
            lots of stuff is rather original on the car so i need to get the motivation to do some testing, which i should have done before posting. but i didn't realize people would fixate on the bodywork as much.
            i will hopefully get the time and weather to look at it tomorrow. i will do some testing and report back.
            thanks for the replies guys.
            • dnguyen1963
              • Nov 2011
              • 2651
              I highly suggest that you look at the Bentley and locate all the grounds.
              • Silver Wagon
                • Jun 2014
                • 184
                so, after a long time of no free time i was able to work on this yesterday. it turns out to be a bad ignition switch. i replaced it and all is well.
