87 fuel pump upgrade.
  • Stevoyayaya3
    • Aug 2013
    • 315
    So I'm pretty sure my fuel pump went out. I was going to upgrade it to the walbro it's cheaper than the 300 dollar oem one. My problem is the 87 unit is different than the newer e30s. Is there a write up on how to fit the walbro to the 87? Thanks guys. I've researched and researched. But it just seems to be the newer e30s
  • Stevoyayaya3
    • Aug 2013
    • 315
    Anyone?
    • ELVA164
      • 4861
      I'll preface this by saying I haven't done it myself, but I'm pretty sure you just remove the transfer pump and replace the high-pressure pump with the walbro.
      • Stevoyayaya3
        • Aug 2013
        • 315
        That's the thing. The pre 87 pump which I have only has one terminal. On the post 87 it has a posi and neg terminal. Also it is a actual pump you can replace. On the pre 87 it's like a plastic pump. It's wierd. I was hoping to have it up and running for Kormans but idk lol
        • vpilarrt
          • Jun 2006
          • 2096
          On the pre 87 the negative pump terminal is just grounded to the metal return tube. You should be able to do the same thing on the Walbro. You may have to shorten the return tube slightly as it looks like it feeds into the pickup strainer which may be part of the pump itself (hard to tell from the pics). You'll need a new sock-type strainer for the Walbro.
          • agent
            Vice Grand Pubaa
            • 7960
            I'm not sure if it will be the same in the 87, but the Walbro I put in my 89 required some modifications that in hindsight I would not do again. Whether it was my fault, a poor DIY or some combination of both, the (much smaller) sock ended up higher than the OEM one which resulted in fuel starvation issues beginning at about half a tank.
            I bought the OEM VDO pump from BMA for less than $200 and it's been great since.
            Originally posted by kronus
            • Stevoyayaya3
              • Aug 2013
              • 315
              Ya i just bought one from bma. It looks like the post 87 pump but it looks like it will hook right up
              • agent
                Vice Grand Pubaa
                • 7960
                I'd be interested to know how it works out since I have an 87 as well. Keep us posted!
                • Stevoyayaya3
                  • Aug 2013
                  • 315
                  Ok update. You can make the early model a single in tank pump but the modifications doesn't seem to be worth it. If it's a project car then sure try it. The early model in-tank transfer pump has a sending and return line. The late model only has a return line. Also the in tank for the early model is a bit different. So I'm still stuck trying to get my m50 back on the road
